Building the Perfect LS1 Roadrace motor...Help From the experts please!
Patriot springs, check.
ARE dry sump, check.
Yellow Terra rockers, crack.
My 1.7 ratio, 2 year old version earlier this year at Summit Point:
I'm just starting a rebuild now. The debate is wether to reuse my forged rotating assembly (gouged cylinder wall requires a new block) or buy a stock long block and reinstall my existing dry sump to save some $$. Still undecided..
Very interested in this thread.
John
John
John, I have the chance to buy a set of YelloTerra rockers from the previous owner and have been told by several people not to go that route. Your pics show "WHY"... I'll probably go the Comp-Cams route once we start spending money. The valve train failures on these cars is what scares me most.
Mike
Mike
I tore down the LS1 shortblock today and laid all the bits out on the table to see exactly what I have...So far I've pulled the cam and here are the specs:
http://www.compcams.com/Company/CC/c...csid=1086&sb=2
I also dug through the boxes of stuff the previous owner gave me, and low and behold there are rockers in one of the boxes, so I ended up with those Yello-Terra Rockers afterall. I'll sell them, I guess.
Main and rod bearings look good on the few caps I removed. Overall the motor seems to be in good shape.
Mike
Mike
So I'm not going the 383 stroker route. Not cost effective from what I'm reading. What would you guys recommend for a heads/cam package? I'll Sell the Patriot 5.3 heads complete with the valvetrain and cam and just refresh the shortblock with forged rods/pistons, and have already planned out the drysump. Also think I'm gonna go the Tilton 5.5 triple disc route.
AFR and RHS seem to make good heads.
OR you could resleeve that motor and but in some cylinders with a 4" bore or more. Then you can use the square-port LS3-style heads.
Dry sump pan rule #1, run screened outlet (suction side) fittings ala:
If something internal ever breaks, it might save your suction pump from major damage.
John
John
How many stages on the pump did you get?
I see pics of lots of Y-Ts cracked and they seem to correlate to spring pressure. There is a gonzo version of the Y-Ts that can handle the pressure, but most people end up with the wrong version for their app and then it goes downhill from there.
