Deleting Secondary Air Injection pump.
Old 10-09-2011, 06:31 PM
Paul Schmidt
Paul Schmidt's Avatar
Default Deleting Secondary Air Injection pump.
I just installed my new motor and want to do a lay down radiator. I have come across the Secondary Air Injection pump. I know what it does with the emissions at start up. I've read that it can be removed and have it tuned out. What have you guys done? Removed it or mount it else where?
Thanks guys,
Old 10-09-2011, 06:39 PM
elite_cyborg
elite_cyborg's Avatar
I just took mine off.
Old 10-09-2011, 06:42 PM
Paul Schmidt
Any codes pop up? Did your check engine light come on?
Old 10-10-2011, 11:57 AM
Paul Schmidt
Anyone else can help me out on this? Any tricks on making this happen with out a check engine light? I'm about to remove this and just want to know what to expect.
Old 10-10-2011, 12:16 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
block off plates on the exhaust manifolds, all AIR stuff in the trash, just remove it in tuning
Old 10-10-2011, 12:44 PM
varkwso
varkwso's Avatar
Removed it and the plumbing on engine. Never had a code and it was not tuned out to my knowledge.
Old 10-10-2011, 12:58 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Ditto.
Old 10-10-2011, 01:03 PM
Paul Schmidt
You guys are the best
Old 10-10-2011, 01:12 PM
Joy of 6
Joy of 6's Avatar
also makes it easier to change sparkplugs
Old 10-10-2011, 07:12 PM
mountainbiker2
mountainbiker2's Avatar
Let's us know what happens. Can you weigh just the pump? That would be great.
Thanks,
Steve A.
Old 10-11-2011, 11:22 PM
Paul Schmidt
Thanks,
Steve A.
4.6 pounds
2.2 pounds
6.8 pounds total.
I also ordered LS1 AIR Block-off Plates for the headers.
Old 10-11-2011, 11:50 PM
mountainbiker2
I wanted to take just the pump off. If I need to smog it, I could just put it back on and leave the hose in place. Would I have to plug the hoses going to the pump?
thanks,
Old 02-26-2012, 06:42 PM
FLYING CANARY
6th Gear
FLYING CANARY's Avatar
where do you get the block off plates from?
Old 02-26-2012, 07:32 PM
varkwso
varkwso's Avatar
I used a gasket and cut it out of a piece of stainless. Regular steel will be fine also.
Old 02-26-2012, 07:35 PM
travisnd
travisnd's Avatar
Thunder Racing sells a block-off kit. Just remove it and cap the vacuum line. There's a check valve in the system that can throw a MIL. I had any related codes turned off with my tune.
Old 02-27-2012, 07:43 AM
davidfarmer
davidfarmer's Avatar
I believe the PCM can sense the extra air via the O2 sensors, but as stated your tuner can block the codes.
To Deleting Secondary Air Injection pump.
Quick Reply: Deleting Secondary Air Injection pump.
