Damper balancing
Old 11-13-2011, 12:10 AM
trackboss
trackboss's Avatar
Safety wire is always a good idea, but I can't imagine how you did that on the balancer bolt
Old 11-13-2011, 01:36 PM
froggy47
froggy47's Avatar
The stock bolt has a lip on it, just enough to catch the drill bit. Long drill bit put two small holes thru the bolt.
Passed the wire thru the holes & put some twist in then down around one of the "spokes" of the damper.
The stock damper has spokes like a wheel.
20 min & I had to sharpen the bit a little too.
Will post a pic next time I get under there.
Quick Reply: Damper balancing
