made my own splitter
I'm thinking of doing this exact thing to my waxer splitter I bought from Pete (Quick ZO6).
Here's what I did to the front of my bumper to increase the airflow.
http://forums.corvetteforum.com/c5-g...-finished.html
Since I posted those pics I added bracing from the bumber to the splitter and the whole setup is suprisingly strong. Here's where I got the braces from.
http://www.wehrsmachine.com/catalog/...eyword=spoiler
Premium Supporting Vendor
Very cool! Great job. I really like the look of it.
I made mine the same way 1/4 abs, working on a new now.
The new front looks like this. don't laugh I cant draw, it's terrible
Hope to see on track soon, I did some stuff this winter too
I can talk to the guy I used and see what his shipping prices are. He can also cut to length whatever you would need.
I think it needs to be a little thicker for track use, the one that was on the Mustang FR500 I race all last year used abs for a splitter but it was 1/2". In some pictures of my C5z06 on the track from a Time Trail you could really see the flex in the 1/4" piece. I found a plastic that was aerated or whipped you might say, so the thicker sheets stayed fairly light, this is what I'll use on my next try in a 3/8" thickness.
I didnt want to pay the huge amount for shipping. You can abs plastic online all over, but shipping is insane. I found a local place that sold .250 thick 4x8 sheets for 120$ the splitter was made from 6'x3'. The piece weighs maybe 3-4 lbs if that. Super light durable stuff.
i used 1/2 mahogany plywood. or luan.... its cheep and if contacts any thing ie ground it just chips away no catastrophi failure....i was at on event when someone kicked out a huge rock after mowing some grass..in i thought i dont think i have enough BAMM..shi/ i didnt think i had enough clearance to get over that...just a bit of bondo and was back to full strength in no time
#36
Nope, just the bumper. All thats needed. I looked under it, and there really isnt much to see. Just a big plate with bolts. To really see whats going on id have to take it off. If anyone is interested i could do a write up or something
#39
it does look really good. i'm interested in how much air flow you're getting since it's a front breather now and where and how much you plan to cut. did you open the radiator shroud behind the hole you put in the license plate area?
#40
No, thats a hole i made when i did drag racing. Was a sealed tube going straight to the TB. i just use it as an access panel now. As of right now i havent changed anything...yet. im working on that. What i use on track cant work on the street. It would never get to temp.
I am working to set up a system so all i do is remove the front plate and a huge increase will flow.
