check valve in valve cover vent on dry sump
Should you run a check valve in the valve cover vent to create more vacuum in the crank? running ARE system with internal oil pump.
I'm talking about the AN fitting from the top of the dry sump tanks to the valve cover. I have one going to a vented catch can and the other one which has the line going into the center vented to the valve cover both with a #10 AN. First start up and 10 minute warm up
http://www.youtube.com/watch?v=xIT_t...ature=youtu.be
It looks to me that you are running a scavenge only system with the stock pump for pressure. I am not sure why ARE suggests venting the motor, but in general you want the motor sealed and only the tank vented. Reason is you are no longer holding much oil in the pan so the scavenge pump draws oil and air. By venting the motor you are allowing a lot more air in and reducing scavenge capability. Also, I would not run an oil cooler on the scavenge line. The scavenge line to the tank may also have air in it so the effectiveness of the oil cooler is reduced. The only time an oil cooler can be used correctly on the scavenge line is if there is an oil/air separator before it (usually built into the pump). If there is a concern for too much vacuum then a pressure relief valve should be installed on the motor.
Speaking for myself, I would be more concerned about setting up the oil system to do the job right than getting the extra hp from the vacuum although it is a nice bonus.
