To shuffle steer or not?
For the first probably 10 HPDE events I used a shuffle steering technique. At a Chin event at Road Atlanta, my instructor wanted me to stop that and claimed that I would be much smoother through the turns by using fixed hand positions. It was a hard habit to break but he was right. At the last Chin event, the classroom instructor dropped a hint that the next classroom session would include shuffle steering techniques. I broke my car so I missed that discussion.
What's everybody's thoughts on shuffle steering?
Jim
Jim
it's a personal thing use it when you need it
if you can compleate the corner with out it do so, when the turn is sharper you need to I cn't imagine how the autocross guys could get by without it
I use shuffle steering in autocross... you just about have to to keep up and stay in front of the cones. For road racing, I don't. You shouldn't ever need to shuffle steer on a road course unless you go off track chasing the car.
It all depends on how big you are, how tall you are, and the steering wheel setup in the car. Being 6'4" 250 I could never drive a stock Corvette without shuffle steering. It's impossible to heel-toe as well. You can drive much better with proper shuffle steering.
In my racecar I have the floor modified and a custom fit ultrashield sitting on the floor (as low as you can get it). I have a Sparco 353 flat bottom wheel as well. Now I can heel-toe w/o issue and could leave my hands fixed if I wanted to. I generally leave them in place, but on certain turns it makes sense to shuffle so your arms aren't crossed up i.e. Turn 4 at VIR. As I'm coming into 4 I move my left hand to the 12 o'clock position and as I'm entering the turn and my right hand goes to 6. As I unwind I move them back to standard position. It makes it far easier to counter-steer when your arms aren't crossed over each other. I'm usually trail braking into 4 so being able to have fast hands is a must.
The idea of 100% fixed hand position only really works in cars with very tight steering ratios i.e formula cars where lock to lock may only be 180 degrees of rotation. In this situation you arms will never get crossed up.
Just my $0.02.
Just my $0.02.
I used to shuffle steer like crazy for autocross. But after 4 National winning drivers told me not to, I finally listened. I would never go back, and only shuffle if it's more then half a turn. You can steer much more precise, and counter steer so fast that you'll have much more control over your car. Practice everyday driving your street car. Half a turn or less, don't take your hands off the wheel. More then half a turn, then shuffle a little.
Check out my videos and you see what I'm talking about.
Good luck
Steve A.
Good luck
Steve A.
Good luck
Steve A.
Good luck
Steve A.
Just my $0.02.
Just my $0.02.
By picking the correct turn in point and radius for T4 at VIR, I can very smoothly drive through T4, hold the radius, then turn into T5, hold the radius then just do a minor adjustments for T6 and T6a. When I get this right, its very smooth and fast.
The consensus is generally fixed position steering depending on how sharp the turns are on the course and the physical arrangement of the driver's body with respect to the steering wheel. Makes sense.
Next time I run with Chin, I'll bring this up with the classroom instructor.
Thanks for all of the input. I'm off to VIR this weekend.
Jim
Like everything, it is a TOOL to be used. I shuffle steer depending on the corner and the car. Since I like to sit close to the wheel for maximum leverage, crossing my arms in a turn is not always possible. In addition. I do it more in the Vette than my Cobra because the trans hump and console are higher and closer to my elbows therefore limiting my space even further.
Received 3,806 Likes
"Ask Tadge" Producer
I always shuffle. Always, always, always. No instructor will ever tell me otherwise or I'll punt them out of the car, simple as that.
jas
Derek Bell once told me that if I started to shuffle steer he was going to get out of the car.
Richard Newton
Newton's Laws
Richard Newton
Newton's Laws
Richard Newton
Newton's Laws
Richard Newton
Newton's Laws
I used to autocross a first gen RX7 that did not have power steering and had a pretty slow steering ratio. Didn't shuffle steer that either and could still put in huge steering angle inputs very quickly. As other posters have also mentioned, you ALWAYS know where straight ahead is and how much to counter steer and if the car steps out a bit, you can catch it without doing a tank slapper..
I never thought about it, but when I looked at my VIR/RD ATL vids, mine are always fixed.
BTW, that is the most fun AX course I have ever seen. Incredible how your hands go way past 6 and 12.
Jim - I hope it wasn't nothing major with your car. The tire thing at VIR was kind of flukey.
Not as harsh, but I agree. I wish I could be so priviledged that I could always have a quick steering rack, on a perfect handling car, on perfectly fresh tires. If only I could make every turn on every race track with minimal input in a cockpit that is designed with plenty of elbow room. When "professionals" and "experts" make such statements, it tells me that it has been a LONG time since they drove a normal American car.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Generally try to keep the hands close to 3 and 9 o'clock. This offers much better leverage and control. The only time I get into the need for shuffling I end up 'throwing' the steering wheel one direction or the other.
With the slow steering ratio in my old GTO, I used to rotate my hands around the wheel (before the turn-in) so that I could get enough rotation to make the corner. It's not exactly "shuffling" more like "pre-steering". With my seat position (I'm short so I need to be closer to the wheel than optimal in order to get the clutch all the way in) and the size of the wheel I can't get the steering wheel 180* around without moving my hands. Maybe a smaller diameter wheel with a quick release mount that I could position further away from me would help but for now my way seems to work for me.
This is probably a better way to describe what I said in my first post in this thread about how I attack T-4 at VIR. I only move my hands in a turn that would have the wheel turned much over 90 degrees. It seems that to some shuffle steering means keeping your hands at 9 and 3 all the time and shuffling back and forth. I don't do that nor would I recommend it.
Exactly... the "never shuffle steer" thing is the ideal, but it's not always practical or possible.
I consider shuffle steering having your hands always at 9 and 3. At our local SCCA autox club, they preach that all the time and they've really perfected it. I'm still not smooth with it and just use it sparingly.
