Install Solid Motor Mounts?
Old Apr 1, 2013 | 08:24 PM
NA_vette's Avatar
NA_vette
Check out the hinson mounts,, nit as harsh as the pfadts
Old Apr 1, 2013 | 10:47 PM
geerookie's Avatar
geerookie
Originally Posted by moespeeds
Jeez them VBP's ain't cheap! I might go with Pfadts in the front, and stock in the rear. It's hard for me to swallow these prices when I have a mill and lathe sitting here, I could make half this crap. For some reason I'm scared to do it on the car, even though I've been doing it on bikes for years. I guess it's just more $ at stake if I screw something up! That VBP unit would be an easy afternoon if I had one in my hand to copy, and about $20 in materials.
There's nothing magic about them. I made a set of solid ones without the poly. I spent the money and tried a set of the Hinson ones but they melted in my race car and ran my brand new ATI damper into the steering rack and that was with stock manifolds, I can't imagine the poly holding up well with headers.
If you go the poly route make sure it can handle the heat.
