Crank and rod bearing PN's for LS2
Old 04-09-2013, 05:13 PM
ScaryFast
ScaryFast's Avatar
Default Crank and rod bearing PN's for LS2
I need to do an LS2 refresh for the track engine. S-D parts has several choices.
Which bearings are you guys using?
TIA!
Old 05-09-2013, 04:08 PM
ScaryFast
ScaryFast's Avatar
Parts found, here's the list for the next guy:
89017571 Crankshaft bearing (Qty 4)
89017572 Crankshaft thrust bearing (Qty 1)
89017573 Connecting rod bearing (Qty 8)
Quick Reply: Crank and rod bearing PN's for LS2
