Can I bounce some alignment numbers off you guys?
Old 06-21-2013, 01:38 PM
Bicyclewrench
Bicyclewrench's Avatar
Default Can I bounce some alignment numbers off you guys?
Stock C4 on Continental DWS's. Driven for occasional road trips but primarily "moonshine runs" (What would you call running the back-roads of WV in a spirited fashion?) and autox. The numbers are "Advanced street" from VBP I believe.
Front
Toe 0"
Camber 0.25* neg
Caster 5.0-7.0* pos
Rear
Toe 1/8in
Camber 0.50* neg
Old 06-21-2013, 03:59 PM
Ludedude
Ludedude's Avatar
what's the question?
Old 06-21-2013, 04:04 PM
Bicyclewrench
More aggressive less aggressive? Am I able to get those numbers on stock parts? Thoughts in general?
Solofast
Solofast's Avatar
Need more negative camber at both ends..
Grind down the conical spacers on the upper control arm mount, or move the thinner rear one to the front and cut off the front one to make it a bunch thinner than the rear one was and that will get you some more camber. You want at least -1 degrees, or 2 if you can get it. If you are running in a stock autocross class you can't do that, but if you aren't go for it, or get a set of offset lower control arm bushings.
In the back you want -1.2 degrees. That will make the car stick like it is on rails.
Old 06-21-2013, 04:07 PM
Solofast
Solofast's Avatar
If you want to stay stock just put a bit more negative in the rear, about -1.2 as I said above and you are in pretty good shape. You would like more negative in the front but you can't get there with stock parts. You'll be lucky to get the -.25 without modding something.
Old 06-21-2013, 04:11 PM
Ludedude
Ludedude's Avatar
The previous answers should point you in the right direction. I don't have enough familiarity with the C4 platform to tell you whether it's achievable.
More camber = better The real tire eater is toe, not camber, even with much higher numbers like I run on the street (-2 fr, -1.5 r) so as long as you keep your toe numbers in check you'll be fine. But again, more = better in turns, worse in braking and accelerating.
Old 06-21-2013, 04:42 PM
Bicyclewrench
Without a tire budget I was trying to stay legal for stock Autox for now.
So -1.2 rear camber
- .25 front (or as much negative as possible on stock stuff) and still streetable?
Old 06-21-2013, 08:39 PM
Solofast
Solofast's Avatar
So -1.2 rear camber
Absolutely and Ludedude is right, keep the toe low to a bit in and you won't eat front tires and you'll be fine. Your toe settings are right on at both ends. Enjoy..
Old 06-22-2013, 03:08 PM
Bicyclewrench
Gracias!
Old 06-22-2013, 09:16 PM
93Rubie
93Rubie's Avatar
So -1.2 rear camber
I got about -.75 on both sides in the front, -1.25 in the rear camber.
Stock toe settings. Wears tires just fine, does track the road a bit compared to stock settings. Handling difference is night and day.
To Can I bounce some alignment numbers off you guys?
Quick Reply: Can I bounce some alignment numbers off you guys?
