What is the best C6z06 oil for track days?
Old 07-28-2013, 09:51 PM
Searya
Searya's Avatar
Default What is the best C6z06 oil for track days?
Looking for what has worked best for oil for track days.
Thanks!
Old 07-28-2013, 10:38 PM
franman69
Support Corvetteforum!
franman69's Avatar
Mobil 1... (I know boring.. works for me. change it after every one or two track days and it's all good).
Old 07-29-2013, 02:42 AM
5280Racer
5280Racer's Avatar
hot race I run Redline 40w
daily driven I run Redline 5W-30
Old 07-29-2013, 08:18 AM
Pumba
Pumba's Avatar
I use Red Line 0W40 oil for both daily driving and track days.
Old 07-29-2013, 10:38 AM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
Pick any decent name-brand oil - Mobil, Amsoil, Redline, Penzoil etc. It really doesn't matter as long as you change the oil/filter at intervals appropriate to how hard you are running it.
Old 07-29-2013, 10:50 AM
Pumba
Pumba's Avatar
Unfortunately, that's no longer true.
In recent years, Mobil and other main line oil suppliers have been following EPA directives and they have significantly reduced the Zinc and Phosphorous in their oils.
These two elements are important ingredients in oil for their anti-wear properties.
Just compare the amount of Zinc and Phosphorous in Mobil 1 versus Red Line or AMSOIL.
Old 07-29-2013, 11:25 AM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
Can you provide conclusive evidence of engine failures caused by the oil?
Old 07-29-2013, 11:29 AM
EyeMaster
EyeMaster's Avatar
For the above post, you can use extended oil change oil or oil for higher mileage vehicles, which have higher zinc and phosphorous in them.
I use Shell 0w40 for diesels, 5w30 Mobil1, Amsoil 0w40 or some of those variants. Right now, my Vette has 4L of 5w30 Mobil1 + 1L 20w50 Amsoil.
Old 07-29-2013, 11:30 AM
EyeMaster
EyeMaster's Avatar
There is some evidence somewhere and it's related to valve, rockers or something like that. Do a search, there really is a potential problem with the lower contents on certain types of engine configurations.
Old 07-29-2013, 11:34 AM
JerryTX
JerryTX's Avatar
http://forums.corvetteforum.com/auto...-oil-tech.html
Old 07-29-2013, 12:47 PM
FASTFATBOY
FASTFATBOY's Avatar
I've used Mobil 1 5-40, Royal Purple 10-40, Pennzoil Ultra Euro 5-40.
All did well in my LS6 Z28 with no oil cooler.
I change mine after every 2 events or 5000 miles whichever comes first.
The Royal Purple is harder to find in 10-40, the Pennzoil Ultra Euro is not available on shelves, I have to order it.
I will most likely stay with the Mobil 1 as you can catch it on sale anywhere.
Old 07-29-2013, 02:36 PM
JohnAlley
JohnAlley's Avatar
Brad Penn 10w-40 for track only car
Old 07-29-2013, 02:48 PM
FASTFATBOY
FASTFATBOY's Avatar
Mine a full street car that gets tracked 4-5 times a year.
Old 07-29-2013, 03:26 PM
ErnieN85
ErnieN85's Avatar
best there is
Old 07-29-2013, 05:14 PM
mesospeedy
mesospeedy's Avatar
I just did my first change in my GS and went with RedLine 5w30. I'll only do hpde and street driving, hoping this will hold up well for both. I asked a rep at RedLine and he said it should hold up to around 280 degree temps, so I think it'll work ok even if I have to do a cool down lap mid session. I debated on the 0w40 but wasn't sure if it'd be a bit on the thick side for the cooler months. I may switch to it tho if the car starts to see a lot of track time.
Old 07-29-2013, 05:18 PM
ErnieN85
ErnieN85's Avatar
Actually I'm using 10-40 and might switch to 5-30 in the winter
My car is in a heated garage so thicker oil doesn't seem to be a problem
Old 07-29-2013, 05:25 PM
db2xpert
db2xpert's Avatar
I've been using Redline for a dozen years since I track the cars.
5w-40
Getting expensive at almost $12/qt, but if it saves an engine, it's inexpensive insurance.
To What is the best C6z06 oil for track days?
Old 07-29-2013, 06:45 PM
08velocity
08velocity's Avatar
St. Jude Donor '13
I've been thinking about changing to this same your using now I think youve helped my descision !! ps, diggin your avatar !!
Old 07-29-2013, 07:46 PM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Thanks!
Assuming you are willing to step away from GM's recommendation for dexos1 oil for a track day, I'd consider this:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
The Z-ROD is near the top end of the 30 grade band, has lots of ZDDP, and is very similar to the AMSOI Dominator Racing 10w30 I use in my 02 Z06 at the track. But the Z-ROD has some detergent/dispersant and is good for about 3-5k mile oil change intervals (or one year whichever first) whereas I change the racing oil at about 500 mile intervals.
This assume an oil temp no hotter than 245-255F or so. Higher than that and I'd consider this:
AMSOIL SAE Synthetic Premium Protection 10w40 (Product Code AMOQT)
(zinc – 1378 ppm, phosphorus 1265 ppm)
I used this oil from about 04-07 when AMSOIL came out with their Dominator Racing line and I switched to the 10w30. With my oil cooler set and larger than stock radiator, my water temp is consistently below 220F and my oil temp is almost always 245-255F even in very hot weather.
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 08-27-2013, 09:31 AM
pkincy
pkincy's Avatar
Has anyone tried the 10-60 oil for BMW M3s? It was specifically developed to provide greater film strength for bearing surfaces under high temperatures when the early E46 M3s were ruining engines on track days.
Expensive, but I have a case or two left from my M3 which is now sold.
I used Mobil 1 15-50 in my LS2 402 on the track as I wanted thicker oil for the 280-300 deg oil temps we got in Az.
Quick Reply: What is the best C6z06 oil for track days?
