Wheel studs & lugs
Old 10-24-2013, 11:58 PM
skxf430
skxf430's Avatar
Default Wheel studs & lugs
How often do you replace both your wheel studs and lugs???
Old 10-25-2013, 12:15 AM
phipp85
phipp85's Avatar
I will replace wheel studs when I change out hubs. If I can't run a lug nut down by hand without it hanging up, I toss it and get a new one. I use the cheap open ended steel ones from NAPA so I have plenty extras.
Old 10-25-2013, 06:13 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I use ARP wheel studs on my car, never had to replace one after 4 years use. Broke two stock studs in a year, and that is what made me change. I use NAPA lugs and replace every two years or when one gets hard to turn on the stud.
Old 10-25-2013, 09:25 PM
UstaB-GS549
UstaB-GS549's Avatar
New lug nuts every 4 or 5 years. The points on the hex start getting sharp edges.
Studs come with the bearing/hub. I replaced 3 hubs in 8 years.
Old 10-26-2013, 12:18 AM
froggy47
froggy47's Avatar
The studs that come with bearings are junk, good for maybe one year. I just threw out 5 new ones that came with an skf bearing I replaced. I replaced with used arp good for 3 yr so far on my car, lug nuts change every yr.
Old 10-26-2013, 06:44 AM
rfn026
rfn026's Avatar
Here's an article I did a few years back on wheel studs and nuts. Keep in mind that a bolt (or wheel stud) is actually a spring. It you stretch a spring too far it won't return to it's original shape.
The biggest killer of wheel studs is the impact gun. Don't let one near your car.
If you really want to get into the science of nuts and bolts here's an article I did last year for Vintage Motorsport magazine. It's a two part article.
Richard Newton
Old 10-27-2013, 10:35 PM
FruiTay
FruiTay's Avatar
I would like to subscribe to this useful information.
Thanks guys
To Wheel studs & lugs
Quick Reply: Wheel studs & lugs
