Hosier R6 on stock wheels
HI guys !
I run 295 on rear with my stock wheel 18x10.5
According to the specification at tirerack we cannot fit 315 on a 10.5 wheel, they recommend a 315 on 11 to 12 inch wheel.
305 would be perfect but Hosier donot make that size.
So either I go with a other brand that make 305 ( kumo ) or i do not listen to tirerack recommendation and go with 315 Hosier
What you guys are thinking ??
Thanks !
Thanks !
Hoser spec is 11 to 12 in wide
Steve A.
Received 8,961 Likes
The Conti's are true slicks Vs the R6 being a DOT compliant tire. The slick has stiffer, shorter sidewalls and has no rim protector. Due to the stiffer sidewalls they they can give installers fits. Similar to installing a run flat tire. Whereas the R6s just slide on like any other non run flat street tire. I have been using them for the last couple of years.
Bill
Bill
