oil temp via OBDII - '03 c5z06
GM Oil Temp: set up custom PID 221154, unit C, max/min 215/-40, equation A-40. It's not exactly correct but it's usually within 5-10 degrees on my DIC. I think this is part of the GM extended PID set that you can access thru the Torque main menu. [...]
I can't get a useable throttle position. I found one, ThrottlePositionE I think, that is 8% at minimum but I don't think it goes anywhere near 100% (altho I haven't checked that close). The default RaceRender throttle position does nothing with my setup (again, C6).
I found Oil Pressure too but it is a little flakey (accurate, but jitters around 2-3 PSI while dash gauge and DIC are steady). Also Transmission Temp but no way to verify if it is accurate (seems to be generally correct, warms up, like that).
Racepak says the same thing, that their OBDII reader won't work with C5's. It is quite frustrating. I've spliced into the car's wiring to get some of the things I wanted but there are still other parameters that I would like, even if the refresh rate was really slow.
This is with a cheapo ELM327 and Torque on a C6.
Mark, how did you get the Oil Pressure to log?
Also anyone figure out how to get the Oil Temp to log?
I can get the Trans Temp, Coolant, RPM, etc. to log just fine. BTW this is for a '02 Z06 using Torque App.
