i am having a problem with my hoosiers rear width 345-35-18 rubbing on the outer fender lip. they are on ccw c10. the stock tires had lots of room.should i go to a 335-30 18. any ideas are appreciated. i did raise the car but i am 1 inch above my ideal setup to clear the tires
Thanks for the replies. Will check the camber and also call ccw they also said these should fit the back spacing could be wrong . I'll post my results thanks
