C5 Z06 Cant get rear lower ball joint to pop loose
I'm trying to undo the rear lower ball joint so that I can replace the wheel bearing.
I have the ball joint stud nut loose about 1/8" The wheel is off and I have a floor jack under the rotor so that the leaf spring is pulling down trying to separate the joint. I tried hitting the side of the upright where the taper fits as well as soaking the top of the stud with PB Blaster.
Any other ideas or tricks?
