C3 Front Rotors for track days. 1978
What is available to replace the stock 1978 rotors.
looking for 11.75" dia 1.25" width to replace stock units.
I am not looking for Big brake upgrades at this time. 4 - 5 track days a year then street driving. Not looking for anything cross drilled.
Running wilwood D8-4 on the front.
Received 8,928 Likes
Bill
Former Vendor
The Wilwood replacement are available only in their Drilled/Slotted format.
I could not in good faith suggest these for track day use due to the potential for premature cracking issues. We all know they are going too...
For track use I think I'd simply pick up some in expensive Centric blanks and run it. You won't find much variation in the options available I bet, most of these are going to be Chinese and likely re boxed (and altered with slots, dimples, whatever) Centric brand parts.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I put stoptech sport slotted cyro treated rotors on mine when I was using Wilwood D8-4s and had no issues for a number of track days. Used carbotech pads and was slowing the car from 130-140 down to 50 or so. That being said, I was generating enough heat to seemingly cook SRF as my pedal would fade slowly...
As a bit cheaper option, here are cyro-treated centric plain rotors.
http://www.tirerack.com/brakes/brake...8&autoModClar=
Stoptech cryo-treated.
I only recommend the cyro-treated as the rotors are so small on our cars that you put so much heat and stress in them if you drive really hard.
