RPM Rollbar Harness Bar & Roll Cages-Free Shipping
Supporting Vendor
St. Jude Donor '11
RPM RollBars Harness Bar & Roll Bars-Free Shipping!
0% Financing available for up to 1 year!
For more prices and options please feel free to contact me at 408/898-4632 or Mikem@TPSMotorsports.com
Are you looking for the ultimate in chassis reinforcement and protection? Look no further than RPM Rollbars! Rob Mathis, owner of RPM has over 25 years of race car and chassis building experience ranging from street cars to top fuel dragsters.
RPM ONLY uses the best material by utilizing light weight and sturdy chrome moly. For those who want to set themselves apart with a rollbar that looks as HOT as it performs RPM offers customized finishes in just about any finish you want! RPM Rollbars sets itself apart by giving an unconditional warranty that NO OTHER MANUFACTURER GIVES.. We guarantee the bar will pass tech, or we'll buy it back!
Why risk getting kicked off the track?
Look no further at so called NHRA/SCCA legal roll bars. This is the only 100% welded, 100% legal, 100% removable, built to SFI standards, on the MARKET and in the INDUSTRY. We guarantee the bar will pass tech, or we'll buy it back!
NOW AVAILABLE WITH REMOVABLE REAR BRACE FOR THE ULTIMATE CHASSIS BRACING!
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
Supporting Vendor
St. Jude Donor '11
Looking for a quality roll cage with quick turnaround and delivery? RPM Roll Cages are shipped as fast as 2 weeks of placing your order
No other rollbar on the market guarantees you'll pass NHRA inspection or your money back!
Supporting Vendor
St. Jude Donor '11
All Rollbars shipped... harness bars should be shipping soon.
Who else would like one? Lead time is less than 2 weeks and can be done as fast 1.5 if it's powder coated.
0% Financing available for up to 1 year and ALL CAR CARE ONE CARDS accepted!
I'm not sure what you mean when you say these bars are 100% legal. They are not SCCA legal and I doubt they are street legal. In fact these look like the would be dangerous to occupants if they were not wearing helmets. The bar is very close to the occupants heads. I hate to think what would happen to anyone sitting in those seats if they were rear ended without wearing helmets.
Supporting Vendor
St. Jude Donor '11
RPM Rollbars generally EXCEED the minimum specs of what is required for most applications.... for example most SCCA/ NASA requires only a small 2x2 foot pad.. where as the RPM pads is 6x6 and contoured to body of your car initializing a top and bottom plate.
Supporting Vendor
St. Jude Donor '11
The bars made per to NHRA rules so they will pass inspection. Bars MUST be in certain positions as per rules. If the seat is reclined ALL THE WAY BACK it would be close to the bar BUT if the driver is concerned about hitting their head they can install rollbar padding AND move the seat forward a bit.
Supporting Vendor
St. Jude Donor '11
I just saw the pictures of your custom rollbar and it is NOT even a 4 point rollbar which means you cannot legally use this for HPDEs. No knowledgeable inspector should allow you to race on a track with that setup. Also, your rollbar is held together with some bolts and not welded together... it is cool that you can remove it and throw it in your trunk but there is nothing legal about the bar. Plus the way the bar is designed you cannot have a passenger AND it does not appear that the top can be put up.. am I wrong? AND lastly the the tubing appears to be ERW Seemed tubing which is the weakest tubing you can buy.
Charlie,
I just saw the pictures of your custom rollbar and it is NOT even a 4 point rollbar which means you cannot legally use this for HPDEs. No knowledgeable inspector should allow you to race on a track with that setup. Also, your rollbar is held together with some bolts and not welded together... it is cool that you can remove it and throw it in your trunk but there is nothing legal about the bar. Plus the way the bar is designed you cannot have a passenger AND it does not appear that the top can be put up.. am I wrong? AND lastly the the tubing appears to be ERW Seemed tubing which is the weakest tubing you can buy. [/url]
Most of what you said about my roll bar is correct. There is NO WAY to put an SCCA legal roll bar in a convertible Corvette and have the top work. The main reasons are that in order for the bar to be safe it has to be too high for the top to operate and the location of legal aft facing supports requires cutting into the bodywork of the car because (if I remember correctly) they need to be within four inches of the top of the bar, need to be at a 45 degree angle, and can't have any bends. As you said, you have to know your requirements when you are putting in a roll bar. For me I wanted a solution that would be as safe as a coupe (without a roll bar) so I could use my car at HPDEs and I needed to be able to safely drive my car on the street as a daily driver. When I was looking at purchasing a roll bar for my car I looked at all of the bars that were available at the time and none of them fit my requirements. They were all too low ( I am 6'tall), they were so far forward that they wouldn't be safe for daily driving (apparently these seats move a lot in a rear end collision), and most of the rear support structures were bent and came almost strait down onto structure that isn't strong enough to handle the load. Also they were installed with Riv nuts which is not an acceptable attachment method for primary structure.
So my Roll bar is definately a compromise, but it met my requirements to be as safe as a coupe (without a roll bar).
The only things you were wrong about were: 1) its suitability for HPDE use. I talked with several of the best HPDE groups in my area prior to building this bar and got approval. I have used it with many different groups since. 2) the material.... I can't remember the material but I brought the SCCA spec to the cage builder and specified the use of the SCCA approved material.
My roll bar was fine for its intended purpose, but as I got a little faster I realized that I needed to upgrade my roll bar, and since their just isn't a good way to put a safe roll bar into a dual purpose convertible, here is how I upgraded my roll bar
Charley
Supporting Vendor
St. Jude Donor '11
Charley
Charley
Charlie,
You are incorrect about there is no way to put a SCCA legal roll bar in a convertible have the top work.. RPM has done several but it is NOT easy. The tubing maybe legal but it's just not the best option available. Obviously your solution worked for you but it's now how I would have addressed it when I owned a shop.
BTW, is that a Radical you have?
Charlie,
Yes, I retired my Corvette to street duty and use the Radical for the track.
Charley
Supporting Vendor
St. Jude Donor '11
Bump for our best sale of the year! Everything is on sale!
Click here to place your orders
http://www.tpsmotorsports.com/black-...-corvette.html
0% Financing Available for up to 1 Year on ALL PURCHASES!
Supporting Vendor
St. Jude Donor '11
Christmas RPM Roll Bar Special!!
It's the gift that keeps on giving ALL YEAR ROUND!
0% Financing Available up to 1 year!
We accept all Car Care One Cards!
Supporting Vendor
St. Jude Donor '11
Didn't get what you wanted to get for Christmas? Get the Roll Bar you've always wanted! No better bolt in roll bar on the market!
ANY color is available for you! If it's avaialable in powder coat it can be yours!
0% financing for up to 1 year available on all RPM Roll Bars purchased from TPS!
Free shipping to any address in the continental USA!
What class are you referring to? Most of RPM Rollbars are catered to HPDE and drag race enthusiasts. I would say the vast majority of their roll bar configurations will pass without an issue BUT YOU MUST know what requirements your class will require. Every class has different requirement.
While private "anything goes" days may have their own standard, I would expect tech at a "real" road race organization to require a few things for a roll bar:
* Diagonal (or some form of double diagonal) bracing for the main hoop
* Fore-aft bracing that departs from the main hoop on both sides, at a reasonable angle, with no bends in it
* No crazy bends or 90* joins straight off the main hoop like this: https://cimg2.ibsrv.net/gimg/www.cor...5b82fc68e1.jpg
My comment was because I didn't see any roll bars in your original post that seemed to meet that kind of standard. If someone has taken RPM bars through SCCA/NASA tech with success wants to chime in that would be welcome, but from my perspective I see a bunch of drag racing stuff that would not pass tech with a road race organization.
Supporting Vendor
St. Jude Donor '11
Sorry, I forgot to respond to this.
RPM makes the Roll bar in any configuration a customer wants... They offer a option which includes a Diagonal SCCA Bar.
