SpeedBleeders Leak
SpeedBleeders Leak
I've heard some people complain about them sporadically over the years. I have also used them for more than 20 yrs on multiple cars with no issues.
These are from SpeedBleeder, not one of the other companies with similar products.
So - installed a set on my vette, AP calipers on front, std Z06 calipers on the rear.
Both on the left rear caliper leaked slightly when hot on the track.
Factory torque for bleeders is 106 inch lbs. Torqued the SpeedBleeders to 130 inch lbs. Still leaked a bit.
Ok, so I finally got a bad set.
Sent them an email Sunday night Feb 28th with contact info.
Called them mid morning Monday, only get voicemail, left msg with callback info.
Tues - no response, left VM and second email
Wed no response
Thurs left VM again.
To date, no response.
Any product can have a problem, but the real test of a company is support and response.
They are history, and I will never deal with them again.
They just lost long time customer!!!!!!!!!!!
Wed no response
I tried them once on my C5 Z06 stock calipers. They lasted about two events than started leaking air into the caliper when used. Leaked around the sealer they put on the barrel of the bleeder and not the bleeder mechanical internals. Changed to using a motive power bleeder which worked great for 8 years. Spend a few $ more and go with Motive - you will not regret it.
