Electronics and sensor solutions for race seats (C6)?
So I think I figured out the slider and seat portion of my race seat install but I am having a bit of trouble with the electronics part. I think I have it figured out but wanted some input before I make my purchases...
I have a 2006 C6, swapping out both the driver and passenger seats for race seats. Drivers seat is power and passenger seat is manual slider. I want to retain the telescoping steering wheel, passenger front airbag functionality, and not have any alarms from sensors.
For the drivers side it looks like I'll need to reuse or buy the OEM wiring harness. With the harness I can plug in the memory seat module and mount that to the race seat.
For the passenger side it looks like I'll need to reuse or buy the OEM wiring harness. With the harness I can plug in the passenger presence weight bladder and mount these to the race seat.
Separately from these I'll need airbag simulators since I won't have side airbags anymore. And I know I'll need some seat receptacle simulators when I use a harness to not get any seat belt alarms.
Is there anything else I'll need to get? I don't want to get all the way through the install and found out I'm missing a small sensor or box or something.
Thanks.
Thanks.
Received 8,929 Likes
Buy your seat harnesses from wrecking yards. A lot cheaper to get and usually just as good. I posted a how to on wiring a pair of single pole double throw relays so you could get around using the memory module. They just replace the relays inside the module. Once you have them wired just splice the wires from them into the appropriate wires on the used seat harness. Not sure what the harness might cost but purchasing the relays at an electronics supply store or on the internet shouldn't be more than $15 plus a few bucks for some wire.
Building the circuit is no where near as hard as adding trailer wiring to your vehicle.
The only issue that you may have with adding the passenger presence module to the passenger seat is calibrating it. Try testing it with 50 and 70 lb weights and see if the indicator on the mirror indicates the passenger air bag is on. Do some research to find out what weight sould turn on the system. If you need to calibrate the sensor I believe you need a Tech 2 to do that.
Bill
Bill
Funny enough as I was typing this I got a call from Dan. Very helpful to talk to him, I think I have it all figured out.
Bill
Bill
Regarding the rest of the harness stuff it looks like Dan was able to come up with a solution for me. Once I get it all in I will share my experiences so this hopefully answers the question for anyone else trying to switch over to race seats.
