Hawk VS Carbotech: which safer for painted wheels
neither/both dependent on how you look at it. ALL race pads have a high iron content. the damage comes from the iron dust made by the pad and the rotor. when that dust gets wet it will rust to the wheel. so wash your wheels after your track day, and change out those pads.
So, performance friction pfc 06 and 08 will not damage your wheels...ever, if you wash them or not. I have not seen the Carbotech RP2's cause any problems, but I've not had them for long.
L8D
L8D
Supporting Vendor
St. Jude Donor '11,'13
Carbotech Performance Brakes™ began 24 years ago. In the beginning we thought like everybody else and made brake compounds out of carbon & iron. The problem with carbon & iron is that when it heats up it forms carbide. Carbide is used in cutting tools, so imagine what that does to your rotors. Along with the fact that those compounds tear up rotors, they also produce very corrosive brake dust. While our competition stills uses carbon & iron as the main ingredients in their compounds, Carbotech started an entire new philosophy eight years ago.
Carbotech Performance Brakes™, the world leader in Ceramic friction materials™. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain contain non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
it's more about preparation than what manufacture to use. If your worried about your wheels coat them with Anti-Slag the welders spray. Or the nascar boys figured out that PAM cooking spray does a god job too. Wash your wheels after the event, when you take your race pads out.
OR
don't give a hoot! On my personal car i use black wheels for street duty mostly because it's harder to see the dust. my car is a 90% track 10% street car. i just refuse to care and let them get all nasty. my track wheels get cleaned after every event as a post race inspection. i look for cracks and whatnot.
if you got nice wheels and you want to keep them nice prep them with anti slag or pam cooking spray.
after your event take the race pads out and wash your wheels.
Supporting Vendor
There is a small amount of iron in the XP series
I would not leave it on for a month. The dust is non corrosive..
C5 Z06 assuming wheels have a coat of wax:
Easy rinse off: XP10, DTC 60 & Ferodo DS1.11
Needs a little scrub with soapy water & probably clean wheels sooner than later : XP12 & DTC70
Don't let wheels get wet unless you are washing them. If you do get the dust get wet and dry off, be prepared to clean wheels with clay bar, CLR, Sonax or similar: Hawk Blue. Great race pad when they are up to temperature, but very rotor unfriendly when cold and terrible clean-up.
Just another opinion
Johnny C @ OG (06-13-2016)
