Where do you get 19x11.5 - 12" wheels for C5Z?
I'm currently running 18x9.5"+50 Front and 19x11"+54 Rear Foregestar F14 wheels. I previous fit 325mm wide Michelin Pilot Super sports on the rear, but it bulged a bit. I went down to 305's now that I switched to Nitto NT01's for the track. The 325/30-19's are around $180 cheaper for the rears. Considering I'll go through 2 sets a year probably, that will add up quickly.
What wheels are out there that I can get in 19x11.5" or 19x12"? May as well go up to 18x10" in the front while I'm at it!
Thanks!
Thanks!
Do the C6Z wheels fit properly on the C5Z? Seems the backspace is .8" deeper than C5Z. I don't mind a little spacing outward. I run 1" lower than stock with aFe coilovers.
I considered it. Thing is, tire prices on R compounds are the same for 305/35-18's as they are for 325/30-19's. Is having more sidewall preferable for track work?
