How to connect AIM Dash to PCM RPM Line???
2001 Z06, C5 stock PCM.
I have completely removed the IPC. I am attempting to connect the RPM sense line of the AIM MXG to the RPM (engine speed) output of the PCM. Specifically, from the PCM pin #10 on connector C2, white wire, that would normally connect to the iPC a pin A17.
Anybody with experience doing this?
GSpeed (01-23-2017)
I don't think you need the pull up resistor. You are using the pulse generated to trigger the unit. It shouldn't hurt but the important thing is setting the tach signal for 4 cylinder.
