Spec Corvette - Car #9 - Build Thread
#41
The Water Temps stayed right around 208-211 degrees out at Autoclub Speedway this past weekend (75 degree ambient temp). That temp was maintained for the duration of the 20-25 min track session.
So far I would say this cheap ECP radiator is working very well and was about 1/4 cost of a Ron Davis.
Olitho (11-07-2017)
#43
Is this the ECP radiator you bought?? If this will work in hot ambient conditions other C5 racers (especially SpecCorvette guys) need to be informed about this radiator.
http://www.speedcooling.com/1997-200...-Radiator.html
mcguirjf (03-15-2018)
#45
Where are you located? Oli needs to drive your car and see how it holds up to the heat. If Oli can't overheat it no one will. I wish I knew about this radiator about 10 years ago when we had to pay blood money for the RD's. Heck a used RD is still more than your's and the construction on youtube looks very very well done with perfect TIG welds
