Anyone here actually put tpms in a pressurized container?
I’m trying to find a way to fools tpms the cheapest way possible. Anyone here actually tried the suggestions of putting it in a pressurized canister and put it in glove box? My understanding is the tpms had to actually rotate to send signals to save battery as it is not constantly on. If someone successful in doing so I’ll invest the time and money to do it. However if someone here tried it and doesn’t work, I’d save my time and money and look or other solution.
Hey Andrie, I tried the canister trick making one out of PVC tubing and you are right, the sensors will periodically go to sleep and when that happens AH goes nuts. So it does not really work. You can pull the steering wheel position sensor which is the mod Mike Huang that you know aka Mikymu came up with and I belive is detailed in his "GT Transformation" thread. You can also get the LG track box which delets the TPS and I believe can be set so that when you fire up the car it automatically turns off TC. Or you can just leave the TPS sensors in, which is what I finally ended up doing with my car and have had no isses with.
I have my sensors in a canister, and it works most of the time . However since I never run active handling or traction control I also have the steering column disconnected
Received 8,928 Likes
You can remove the connector from the steering connector but be careful when you do that as the connector isn't a high duty cycle connector and is on the fragile side as the designer more than likely chose it since they didn't expect it to be taken apart more than 20 times over the life time of the car. Once removed you will still have ABS and Traction Control but all AH functions will be turned off since AH needs the steering sensor to initiate AH action.
Bill
