NASA NE ST-2 (Re-)Build Thread
After 7 years of fierce competition and more second place finishes than I'd like to admit, it's time to rebuild the NASA NE ST-2 #38 car that I've been campaigning since 2011 in the Northeast Region. Over those years the car has survived three major crashes, a clutch explosion and two engine fires along with the general wear and tear that any race car experiences.
While myself and my team did a fairly good job of prep, maintenance and repairs over the years, we lacked the support of a well seasoned race shop to achieve the setup and reliability needed to stay competitive and most importantly- finish a full season.
After my latest fiasco (blown engine and resulting fire at Lime Rock this past August), I've decided to hand the car over to Adrian and his team at F.A.S.T Auto in Maspeth, NY and perform a complete rebuild. To give you an idea of what we are undertaking, I've included a picture of the car from the 2016 NASA East Coast Nationals at Watkins Glen. I'll add that the only parts that will be on the new build will be the transmission (a T-6060 Transzilla in a T-56 case) and diff (an OZ Giken with 3.91 gears) which all have low hours. We are reusing the frame rails and firewall but just about everything else will be new.
The build is going to include new body work from Kerry Hitt at ACP (a combination of different body kits) plus incorporating some of our own pieces (such as a lightweight marine grade plywood undertray with carbon fiber tunnels) and a custom diffuser inspired by (stolen from?) the C7-R Corvette. The engine is going to be an off the shelf, LS-3 480HP crate motor using a few upgrades such as a custom Evans Racing Water Pump and ARE 3 stage dry sump with engine management performed by the matching GM ECU. Previously I've run the same motor but controlled it via the C5 ECU which had limitations and other challenges. The Stoptech ST-60 fronts and ST-40 rears will be now managed by a Bosch M4 ABS unit. These two units will pass data into an Aim MXG via CAN bus and simply the wiring tremendously while providing tons of critical data.
Were also going to be using a ton of parts from forum supporting vendors like Mark from AMT Motorsports (his new motor mounts and seat mount) and few others who we will be sure to point out along the way.
And for those of you who aren't familiar with F.A.S.T Auto Racing, be sure to check out their new video: https://www.youtube.com/watch?v=V0-i...ature=youtu.be
To give you an idea of why we decided to perform a complete rebuild, I'll include some pics. Here's the car AFTER the Championship race at the Glen in 2016.
While the rear tub was repaired last winter, it was the second such time and was badly beaten. After discussing it with Adrian, we made the decision to purchase a rear clip and graft onto the existing frame. We located a Millinium Yellow rear clip in Wisconsin and had it shipped to us.
In the meantime, Adrian and crew began to strip the car down.
Eric, Adrian and Kuba take a minute to pose after a long night of work. I swear these guys never sleep (as evidenced by these pictures being texted to me after midnight on random weeknights).
The rear bumper had been straightened so many times (a broken rear spindle introduced me to the pit wall at NJMP- Thunderbolt in 2015) that the wing mounts weren't sitting the way I liked so we used the donor from the new rear clip.
Adrian decided he wanted to install the entire clip with the roof still attached in order to get the best possible alignment. It was a good call (and the roof just happened to be the only body panel from the original car).
It's starting to look like a car again!
With everything lined up the rear quarters will be removed in favor of the ACP wide fenders that allow a 13" rim and LG dropped spindles to clear perfectly with 345/35/18 Hoosier A7's. (If anyone needs two nice Mil Yel rear quarters, they are listed CHEAP in the C5 section!)
The new engine and computer has arrived and as soon as the engine bay is painted and prepped- it will be going in.
That's pretty much where we are now. I'll continue to post progress photos as we move forward. We're hoping to have everything done and ready for some testing (somewhere warm preferably) before the 2018 NASA Northeast season kicks off.
Questions are always welcome and I'm sure Adrian will have plenty to add.
jloZ06 (01-20-2018)
Classic case of "Play to Pay". I will admit that over the years, I tried to reinvent the wheel with "solutions" to problems that already had been solved and probably would have spent less to do some thing differently the first time. Most of this was based on budget but some things I still believe are more cost effective with budget solutions. Case in point.... splitters. I still believe that unless someone with VERY deep pockets is paying for your expendibles, you can do just as good with marine grade plywood as opposed to carbon fiber.
Yes... the wing is only about a season old. It was a custom AJ Hartman piece he made for me to work with the exisiting uprights I had on the car. We'll be tweaking the mounting system slightly. Were most likely going to create some welded on steel brackets that will adapt to the aluminum uprights. Those were actually just fabricated last year after the incident at the Glen.
Mordeth (01-01-2018)
[QUOTE=Hi Volts Z06;1596292580. Case in point.... splitters. I still believe that unless someone with VERY deep pockets is paying for your expendibles, you can do just as good with marine grade plywood as opposed to carbon fiber.[/QUOTE]
LOL! yeah and the wood's heavier weight is low in the chassis...win...win.
I have resisted moving up in class with all of my friends but 1. Having to fix the ripped off splitters when going off track is just a pain I don't want. I get a chuckle that spares in their trailers also include a 4x8 sheet of plywood and a jigsaw.
Oh...I think the other cool thing is you are investing in the old C5 chassis. A C5 just won the SCCA Runoffs at Indy in my class too. The old C5 is a great chassis and still winning!
I agree, but I had to go aero back in 2013 to stay competitive. In the last four years, I have built five splitters and three right side skirts. Damage from scales at the track, off-track excursions, and car-car contact.
I'll post up some pics once we start re-assembly of that portion of the car.
What's left of my ARE dry sump pan after the motor let go at Lime Rock.
