Coilover springs - what brands are close to advertised rates ?
I have now bought 2 x sets of coilover springs for my rear coilovers.
A pair of QA1's rated at 350 lbs - tested at 331 lbs.
A pair from a business that sells to the riceburners and drifters, rated at 7.5 kg - which converts to around 400 - 420 lbs - actual rate 291 lbs !
for the people that have tested their springs against the advertised rate over the years, which brands are usually close ?
below on the left is the spring that was sold to me as being around 400 lbs against a real 450 lb spring.
blackozvet (05-24-2018)
Supporting Vendor
Swift, hyperco, or eibach. Beware of spring shape on hyperco, see this thread-
https://www.corvetteforum.com/forums...to-tierod.html
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
thanks guys, good to know, I can get Hyperco in Aus, if I want Eibach will have to get them from Summit.
The guy who tested my springs said that typically most coil springs that he tests are anything up to 10% below advertised rate - which isnt really helpful if targetting a certain spring rate for the track !
its amazing how a 'fat' spring can cause clearance issues, had that in the front going to a higher rate.
