Keeping cool
Keeping cool
I am struggling with my dads car and my car with keeping coolant temps down. Oil temps aren't an issue but our coolant temps are. Both cars will over heat in about 5 laps 250+ coolant temps. The outside air temp last weekend was 92 degrees roughly.
My car:
Dewitt's radiator
Pro speed fans
Improved racing oil cooler in front
Evans coolant
Stock water pump
160 degree t-stat
MCM heat extractor hood
My dads
Ron Davis radiator with oil cooler built in
Stock fan
Evans coolant
160 t stat
Evans coolant
Katech hood
What's everyone doing to keep your car cool for a 20-30 minute session? Is a miezre water pump worth the upgrade? Different hood with more louvers in it such as LG? Any other thoughts or ideas would be greatly appreciated.
My car:
Dewitt's radiator
Pro speed fans
Evans coolant
Stock water pump
160 degree t-stat
My dads
Stock fan
Evans coolant
160 t stat
Evans coolant
Katech hood
Supporting Vendor
Stock radiator shroud? Stock motor? No reason that Ron Davis shouldn't keep everything cool. Air in the system? Radiator plugged full of crap? Did you just change the coolant or anything? FYI I was having overheating issues just recently after 5 laps, when my car usually runs at 170 water temp. I did what I could to burp the cooling system and it took another half gallon of water. Everything seems normal now but I won't know for certain til Watkins Glen next week.
My car: built Ls7
Dads car: Katech built motor with RHS block
No air in the system we have one of those high dollar snap on tools to get air on out the system and pressurize it.
Change coolant: has Evans coolant
My dad and I both were having over heating issues and our good friend with a c6z all stock minus a dewitta radiator was having overheating issues as well. So I don't think it has to do with our parts. I think it has to do with ether it is what it is or changing stuff and trying something new. I am curious what everyone else is doing for cooling.
Former Vendor
Here's why
BigMonkey73 (05-31-2018)
Supporting Vendor
Stock radiator shroud? Yes both cars
My car: built Ls7
My car: built Ls7
So that's a pretty serious race car cooling solution which you may or may not want to undertake if your car is dual purpose.
My car:
Dewitt's radiator
Pro speed fans
Evans coolant
Stock water pump
160 degree t-stat
My dads
Stock fan
Evans coolant
160 t stat
Evans coolant
Katech hood
My car:
Dewitt's radiator
Pro speed fans
Evans coolant
Stock water pump
160 degree t-stat
My dads
Stock fan
Evans coolant
160 t stat
Evans coolant
Katech hood
Ducting is your friend. You need to force air through the radiator. Make sure everything is sealed up.
