OEM Front speed sensor bracket thickness?
reposting here as haven’t had luck in C6 forum...
For c6 z06, can anyone tell me the thickness of the OEM spend sensor bracket?
I swapped to LG front brake ducts and can't find mine, trying to verify if the OEM bracket is the same thickness as the LG brake duct spindle which is 1.5mm. Want to make sure before installing my AP front brake kit.
TIA
TIA
FYI I found the OEM part numbers for the speed sensor brackets (10263081 & 10263082), ordered and measured.
For reference they are ~1.4mm thick so a difference of ~0.1mm from LG spindle ducts.
I don't anticipate this small difference should have any impact on factory or aftermarket big brake kits.
