Run newer slicks front or back?
Is it best to run the better tires up front or on the rear? Was a thread a couple of years ago, but I cannot remember. Car has 520rwhp if that matters.
Experiences?
Experiences?
Received 8,930 Likes
Always run best handling tires in the rear. Otherwise you can get a massive unexpected over steer when the front grips going into a turn and the rear doesn't.
Bill
Bill
GSpeed (11-19-2018)
Sr.Random input generator
But fronts usually get done sooner, so unless you run square, you might need to end up running newer rubber up front. Just be careful until you know how it feels (balance, etc.). ... Or you can just replace all four : )
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I must be in the minority here. I would rather fight a loose car than a tight one. I always put the best tires on the front. Know that going into a corner and be prepared for what you know will happen. Better tires in the back will overdrive the fronts and just make it push all day.
I have never run new grippy tires on one end and not the other if you can believe that with all the racing I do.
But a contrarian idea, if this is a square setup I would think I would mount the two new tires on the side of the car doing the most work on that track.
Wouldn't that drive the differential nuts since the diameters would likely be more off than they should from side to side? These are not race cars, after all..
Interesting thought. So like at VIR and RD ATL where I do most of my tracking, I would want them on the left side? I just did Sat and Sun at VIR, so I would have had plenty of track time to test that.
Bill
Not such a crazy idea, I do this all the time on autocross courses, I know track racing is different, but some autocross events have 10 left hand turns and 3 rights all under 70 mph on a flat track, so in that situation, it makes perfect sense.
