C5 Tire ?
C5 Tire ?
I picked up a set of 2001 Z06 Wheels for my 97. I'm going to Auto-X a few times a summer and want to use the Z06 wheels for that. Tire suggestions for that? I want to go 200TW or harder. Options seem limited. No street use for this set so what's your input.
Two options that I know of would be BFG Rival S or Yokohama Advan 052, Hopefully your area SCCA has a street tire class for SSP or you will be running in a very tough class. If you are running NCCC events you are OK, I am not sure of other groups.
boomnzoom (04-02-2019)
That said, you might also consider adding Bridgestone Potenza RE71Rs to your short list. Normally less expensive and better suited to single-driver, sub 60-second course designs, they can give the BFG Rival S a run for its money. Both of them are 200 TW.
Early C5s have their own brand of fast. Have a blast!
Supporting Vendor
I can help. Assume you want to be on at 200 treadwell set. The ZO6 wheels as a complete set are not exactly optimal because of the 17x9.5-in front wheel. They're just really aren't fast 200 treadwear tires that come in anything bigger than 255. That said they are pretty impressive, we have run that setup on cars doing some testing and you give up very little front grip versus say a 275 on an 18 by 9.5.
now maybe you are looking to do something other than run 200 treadwear street tires. In which case things get a little bit more easy in terms of size option. But then you're going to end up running in either SSP or SSM on something like a Hoosier.
I carry tires. I am extremely priced competitive with big boys like tire rack. I know these tires like the back of my hand because I deal with them on a constant basis between setting up cars for national events, teaching schools and driving other people's cars, and the fact that right now at this current moment I own More tires than any same person should have including, but not limited to, BFGs, bridgestones, Hoosiers, Pilot Sport cup 2, a different set of pilots for the street, and a set of continental extreme contact sports. Notice I said not limited to because I have other tires as well. Why do I have this many tires? Because I do a lot of testing.
Also, agree with everyone here that this is a bad idea as it would move your car (if its stock) way up into STU or CAM-S classes.
Easy answer - buy a C6 front wheel (18x8.5) and buy a set of C5 rears (18x9.5)... they will be miss matched by style but will meet the street class requirements. RE71's will probably be your best bet in these sizes. 265/35 or 275/35-18 up front and 285/30-18 in the rear... the short rears will lower your effective gear ratio, which is a plus for autocross.
Unfortunately, the BFG Rival S 1.5 isn't very Vette friendly in the size offerings...
Nobody's recommendation is going to mean squat to you until you tell us this.
Easy answer - buy a C6 front wheel (18x8.5) and buy a set of C5 rears (18x9.5)... they will be miss matched by style but will meet the street class requirements. RE71's will probably be your best bet in these sizes. 265/35 or 275/35-18 up front and 285/30-18 in the rear... the short rears will lower your effective gear ratio, which is a plus for autocross..
My street tires are older R-S3s (Version 2) from a long-forgotten AX season. But they're more versatile even if they're not a current autocross-specific front runner. And they last forever on my lighter, stock FRC.
Jesup16, the OP cannot run in the stock class so he would be bumped to SSP using the Z06 wheels. They are available in a 265/315 sizes for the Z06 rims so it is an option
^ +1
Super Street Prepared is a formidable class, first 10 of 11 placers in the SCCA Solo Nationals were Z06s, the rest being R8, McLaren and turbo 911s. Quite a (frustrating) reach for an otherwise stock 1997 C5.
Local events are another matter, altogether. As mentioned above, a lot depends on which organization is running the event. SCCA has so many classes, events very often have one car, or none, for each class. And, if just for fun runs, it's alright. After more than a couple of events, though, the competitive edge may emerge and it's time to pay attention to classification.
Again, this thread is useless without the OP telling us what class/prep level he is targeting.
I haven't thought about class yet. Stock 97, with the rim/tire combo that I'm looking at. At this point I'm not to concerned about class as I will be looking to improve my driving skills and drop a little time. Mostly local events for now but Salt Lake City is close and has SCCA events almost every weekend in the summer.
Also, a set of Z06 wheels is 18-15 years old at this point. The likely hood of getting a set that's not bent, cracked, etc is slim. Again, call Sam. He will set you straight. I wish I had when I started autocrossing...
