20mm difference: BFG vs Michelin
Sr.Random input generator
IIRC, you should have them both mounted (or unmounted, though less desirable). Otherwise, the numbers might get misleading.
smitty2919 (06-26-2019)
You can easily see 10+ mm of lost contact patch on the bfgs on this side. So 20 mm total. So it's exactly as it states.
The extra width of the 305 is coming from the wheel pushing the sidewall outward. For an apples-to-apples comparison, I think you'd need to either...
a) mount the 325 on a 13" wheel. That might push its sidewall out an extra 10mm or so
b) un-mount the 305 so the wheel doesn't move beads (and thus the sidewalls) so far outward
For reference, Spec Corvette runs 315s on 10.5" wheels. You've got a nominally-narrower tire (305) on a definitely-inch-and-a-half-wider wheel (12"). So naturally the tire looks extra wide.
For reference, Spec Corvette runs 315s on 10.5" wheels. You've got a nominally-narrower tire (305) on a definitely-and-a-half-wider wheel (12"). So naturally the tire looks extra wide.
NSFW (06-26-2019)
I just did it as a comparison now that the rival-s is offered in 19" sizes. Porsche runs 305s on 12" wide wheels for the gt cars, so I was curious as how much difference there would be.
NSFW (06-26-2019)
The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim.
Note: Because the overall diameter of a steel-belted radial is essentially determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
