Track alignment
My main question is, my 18x10 and 18x13 ccws i will be getting the entire alignment done with them on as they are my track wheels. Now when i drive around town and out to dinners or road trips ill have my stockers on which are 18x9.5? in front and 19x12? (Not 100% sure on widths) but, how will this track alignment affect a different wheel size. Is it dangerous for suspension components? Excessive tire wear i assume? Not sure, do people get another alognment after track days for stock sizes and do that every time, no way! Has to be some solution or middle ground i guess. Any help is appreciated!
I rock way way more aggressive settings than you, and uniballs, I did 3000km to germany, then austria, a few days on the nurburgring, and horrible rain etc on pilot super sports on stock z06 wheels. Just gotto go slow on rain, and it will wear the inners, and you have to be careful on rain.
Any street/track dual purpose alignment will be a compromise. Enough neg camber for the track is too much for the street, and a typical track alignment would feature a little F toe out to help with turn-in.
Tires are generally more forgiving of camber than they are of toe...
"Just enough" neg camber for the track will lengthen tire life there, and only slightly compromises street tire life. It's a good trade off.
"A little" front toe out to help with the car cut is of minor benefit on the track, but will shred the tires on the street. Not a good compromise, IMO.
Zero, or a breath of F toe in, and for sure run toe in at the rear for stability.
Different tire/wheel combinations might make the car feel different... excess neg camber can reduce the straight-line contact patch enough to compromise braking. Shouldn't be an issue, but maybe feel it out with the street tires ahead of time.
great! Thanks a ton, as i talked with the shop whos doing alignment he recommended a street/track setup. So recommending the specs he did i should he fine with both then i believe, at least a little better on track than stock alignment. As long as when i put street wheels on im not hurting my suspension or endangering my street driving, ill be alright. Thanks a ton
