C8 Autocross Alignment
The car is primarily used for street driving and will probably be AX’ed 3 - 5 times a year.
Thanks much!
Motor Trend Track Alignment Article
Chevy's Specs
Front
Camber 3.0
Castor 8.0
toe 0.05 degree
Rear
Camber 2.5
toe 0.05 degree
This was with the stock tire (a 4S? I think)
Starting pressure 25psi !!?!
Thanks much!
We just did an alignment on our C8 Z51 and ran a couple days at Thunder Hill with it. We modified the GM recommended settings a little to help with turn in and reduce the steady state push the C8 has mid corner. It seemed to help a little and we's likely go even a little more aggressive with toe changes for an auto cross only alignment. The issue with trying to get a "do it all" type alignment on these is that it will be hard to find something that will work well for auto cross and not wear the tires on the street. You certainly can't go as aggressive as the GM recommended settings and expect to not kill the tires on the street.
We had -3.5 in the front of our car and -2.3 in the back. On the road course the tires showed really good wear and we could've been even a little more aggressive to optimize tire temps and wear even further.
We'd be happy to do the alignment for you and try to come up with a medium aggressive setup that would work for you. The initial alignment on these does take a lot more time if you're removing washers to get fairly aggressive with it.
I slept on it and have come to the conclusion that I just need to go out and drive the car, and not worry about setup. It's been quite a while since I really devoted time to autocrossing. If the car handles well and I get the "bug", then I'll consider alignment.
Again, thanks very much!
I was running a '15 Z06, probably with Hoosiers, when I saw you run. My driving skills were probably not up to the car, but having stepped out of a '13 Grand Sport, I always felt the Z06 just didn't communicate in a timely manner. It was kind of numb. The GS, on the other hand, talked to me and my times reflected that. Now, I say this with acknowledgement that the driver has a tremendous bearing on the car's ultimate performance, and I'll accept the blame. Even tho I tried many different setting in Track mode and Sport, just never found one that worked for me. Yes, even disconnected all of the nannies, too.
Since writing this thread, I've had time to further consider alignment and have come to the conclusion that I just need to go out and drive the car, and not worry about setup. It's been a while since I really devoted time to autocrossing. If the car handles well (and I know it will) and I get the "bug", then I'll consider aligning down the road.
I've heard a lot about your dealership and look forward to seeing it, if I decide to delve into setting up my car.
Thanks very much for responding with your offer to set the car up. Hope to see you at Thunderhill on the 20th.
Bill
Edit: Might assume it could have something to do with the weight balance/transfer...but still surprising
Thanks for the kind words. If you decide that you want to try something less aggressive, but better than stock, we can certainly make that work. The benefits of a full blown auto cross setup will make a big difference, but any changes to the stock alignment will also help.
I won't be at the track this weekend, but I hope to make it up to one of the events later in the summer. Have fun and be fast!
Toe-in yes not the most best alignment setting in AX, but a nice general guideline for tracking/stability. As I understand it you want toe-out in front for an ideal AX setup, for better turn-in, but now we're talking about maximizing the setup, and the car/tracking will then wander some normally. I don't believe you EVER want toe-out in the rear..
This would presumably be identical for either powertrain configuration...toe and camber should always help performance handling for the most part, at the expense of normal-driving wear of course.
In terms of mid engine versus front engine settings, you can get a way with a much greater amount of negative camber in the rear of a mid engine car because of the rear weight bias and how well it will put power down.
Can you carry the same entry speeds as a C6Z or need to rely more on exit power and squaring things off?
