So, I've made the switch to a C7 Grand sport as my track car.
As I start checking off boxes in preparation, I'm looking into Data loggers. Unfortunately, my car was not equipped with the PDR.
The AIM SOLO 2 DL looks like the easy button and has a lot of support. I was and am still happy with my original AIM solo in my E36 and other pre-CAN cars I've tracked.
Is the AIM still a favored logger?
I also was also curious if anyone is logging the shock encoders and are they able to be read thru the OBD connection.
Shoe
The easy 5 minute solution is still Solo2DL. Only thing I don't like about it is the wireless download takes forever to connect and download for me, so I've moved away from them unless its something really last minute. I also found a max number of channels it could record which I bumped into doing testing of my own can bus profiles.
AIM doesn't have the shock sensors in their available CAN profile. I've done my own one for the C7s/Camaro that has just about everything that PDR has. Shocks, Tire Pressure/Temp, driver modes, TC settings, etc.
You got all that to work on an AIM SOLO DL? Curious because it seems like people were having trouble getting data like brake trace or steering, all things that PDR records. I wonder if your CAN channels would be the same as the ones used on newer C6s so that your profile could get brake traces, steering, etc.
AJ is very good with electronics integration in the vettes. You might be able to buy it from him, but the time suck to get what we all want on that is very high.
Just the AIM solo DL data that IS logged is stil very powerful. Most temps, pressures, and a lot of useful info.
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
AIM Solo2DL - custom CAN profiles for the RS3 based stuff can be built. You can not for RS2 with the original SoloDL. I never had trouble with the AIM C7 profile but have read about issues with codes, starting.etc. Once I learned what to do I saw there was a lot more out there that was worthwhile to record and use to troubleshoot. The C6 CAN doesn't have much data on it since it was the first go around for GM. The C6 does have steering position (unless you've disconnected the steering position sensor for TPMS disable purposes) and does have a brake pedal position via the BCM (not pressure). I've found and pulled ABS warnings/events too. The more data the better so I found it was worth the time to dig.
Yes I have sold it, but so far only for dashs/loggers that I program in house.
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
i have no idea why but the config for the c7 from aim (the last time i looked) was weirdly limited.
I've been running a custom config for years and have *almost" everything the PDR captures (none of the suspension stuff)
it would be nice to get eLSD data logged but not sure if thats possible.
So if I fumble around long around in RS3 and build a profile for a C6 GS, I could add brake pedal position and those ABS events? Is that something a commoner could do or best left to experts to construct?
From what I've been told is that is what they found easily, or what was shared or given to them. The C7 / Gen 6 Camaro, G8, and Gen 5 camaro have some similarities that I'd guess spread across other GM cars as well so they may have used something not exact. (or from/in Europe to get it going) For example the I think the Gear in the standard AIM profile only works with automatics. Also the amount of time it takes to really dig is another factor. C6 is easy as not much going on. C7 has 3x or 4x the amount of data the C6 has on the main bus. The C8 is whole different ballgame, tons more addresses and channels.(along with 2 or 3 more bus's). I started, spent 3 weeks on it, found the basics and some more, but since we didn't track the C8 again I didn't finish it.
Originally Posted by Pshoe
I'll have a couple friends that know more than I do both about the AIM and CAN.
What one tells me is that acquiring addresses would be helpful.
At any rate the additional data over my older AIM will be helpful
Yes, and that is where all time working on it is at.
Depends on what tools you have at your disposal. You can not take an AIM Can profile and add to it, you need to build your own from scratch, which means figuring out where those channels they already have are located.
