NUMBERS
Old Jan 21, 2003 | 07:52 PM
Dakota Slim's Avatar
Dakota Slim
Default NUMBERS
Does anyone have a good suggestion for where I can find number that will stay on a Vette at Road Course speeds? I hate to use tape but so far static cling I have use don't seem to stick well. Ideas????
:auto: :steering: :auto: :steering:
Old Jan 21, 2003 | 09:12 PM
Reeves's Avatar
Reeves
From: The inmates are running the asylum... San Jose, CA
Default Re: NUMBERS (Dakota Slim)
Try vinyl numbers from a sign shop, the kind used for making commercial car stickers. They go on easily and come off fairly easily when warm (leave the car in the sun or use a hair dryer).
Out on the left-coast I've bought my numbers from Fast Signs but just about any sign shop should be able to do them.
Reeves
Old Jan 21, 2003 | 09:21 PM
GTB/ZR-1's Avatar
GTB/ZR-1
These numbers will definitely stick...
http://www.protapesigns.com/racinggraphics.html
George
Old Jan 22, 2003 | 01:05 PM
jiml94's Avatar
jiml94
D.S.: Here is one fix that works and is cheap! Take your large numbers (from a printer,etc) and trace them on a stiff piece of cardboard for a template.. Now go to Home Depot, Lowe's, Walmart, etc. and find some Contact Brand shelf lining paper. Then trace the numbers onto the shelf paper with a felt tip pen and cut out. Peel the backing off and apply to car. They will stick at any speed. When the event is over, just peel off nad discard. Their should be no adhesive residue but if there is, just use some mineral spirits (paint thinner) to get it off. It will not harm your clearcoat. This is a tried and true method and will cost about $5 for the shelf paper.
Old Jan 22, 2003 | 03:56 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Default Re: NUMBERS (jiml94)
I use the shelf paper thing too.
Super cheap and very easy to do. You can make numbers any style you want. I also buy the low tack shelf paper and it sticks perfect at high and low speeds and then when I take it off, it comes right off. No residue at all.
Old Jan 22, 2003 | 10:18 PM
YorkL8apex's Avatar
YorkL8apex
Default Re: NUMBERS (fastzr1)
:iagree:
Old Jan 24, 2003 | 01:16 PM
ZR1 MK's Avatar
ZR1 MK
I use reusable vinyl numbers on the glass, but they should work on the painted surface as well. And you can reuse them for years.
Mike
Old Jan 24, 2003 | 05:14 PM
VetteDrmr's Avatar
VetteDrmr
Use some electrical tape on the leading edges of the numbers to hold them in place. What I did was have my numbers put on a square piece of clear static cling plastic. Then I just anchor the leading edge of the clear to the car. No problems lifting.
Hope this helps,
Mike
To NUMBERS
