Is there a push button start how to for C5 racecar somewhere? I know to do the VATS resistor but what about the rest? I think something in ignition area needs to power up before the push button can trigger the starter.
Spec Corvette Racer Kevin Jones has a fantastic kit. I will email you his info as I don't think he has a website. He makes stuff that is better than package shelf product. You need to see it to appreciate it.
IMO first tune the vats and any other no essential system off in the pcm. Then the rest is simple use a stop light switch to power up starter push button switch. You also want to check rule book if applicable. Sanctioning bodies may have other safety requirements, intended to prevent accidental engine start particularly with no one in the car.
In the process of caging my car and looking for the push button start kit above.
Anyone able to give me a contact to purchase the above kit in the video ?
cheers
SpecCorvette kevin makes a plug n play kit for 250 or so...can't remember but that's what I used. It was perfect, easy and well made! PM me for contact
I ended up getting the kit from Kevin , wanted to just follow up that it’s extremely nice and easy to use. Even came with instructions which I wasn’t expecting. Works perfectly .
Really helped clean up the dash and organize the car. I had an old “starter” backing plate from another car that I used his switches in and mounted to my dash .
