Is anyone else having trouble keeping the static aligment consistant? Seems like my alignment always moves. I have the camber ecentrics torqed to 125 ft-lbs on front and rear. I had the toe on the LR move last weekend...that was a first, problem was the jam nut was still tight. Go figure!
Happens on the rear of the C4 also. I mark all the cams with paint so I can see at a glance if anything has moved. It does not keep them from moving, but it lets you see before/after an event if it has changed. If it moves just line your marks back up and you should still be near your correct settings. :chevy
I alignment never changed on mine until the A Arms slid backwards on the bushings. You may be the victim of the machine. Sometimes all you have to do is back off the machine and drive back on and the numbers come out differently.
However, if either your camber or caster changes the toe will also change. The tie rods only set the toe once camber and caster are locked in. If either changes the relative wheel position changes and that is going to cause a change in toe since the tie rods don't automatically change to make up for the movement.
This is the problem I had at Rd Atlanta. I was running an OEM adjuster in 1 (of the 6) locations, due to too-much camber with the GM camber plates. It worked just loose enough that the concentric could twist. Big problem on a 600HP car!
I replaced it with a home-made camber plate, with the hole further in than the GM camber plates
