Understeer
Old Aug 24, 2003 | 08:24 PM
swoosh's Avatar
swoosh
Default Understeer
96 C4. What can I do get rid of the understeer?
Old Aug 24, 2003 | 08:40 PM
davidfarmer's Avatar
davidfarmer
Default Re: Understeer (swoosh)
stock car??
more neg camber front, toe front out slightly, raise rear (or lower front) of car
Old Aug 24, 2003 | 08:49 PM
swoosh's Avatar
swoosh
Default Re: Understeer (davidfarmer)
Sorry this is a stock car. Can you give me some specific numbers?? Thanks
Old Aug 26, 2003 | 12:02 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Z51 or base?
The base cars have 8.5" rims in the front 9.5 rims in the back
with 255f 285r tires
The Z51 cars run 275's on 9.5" rims all the way around.
also the swaybars are different.
big difference.
Old Aug 26, 2003 | 12:34 AM
mvitacco's Avatar
mvitacco
Try -1.5 camber front with 0 toe
-1 camber rear with 1/16 (total) toe
I find this made a big improvement while still providing good tire wear for a
daily driver on street tires. THese spec are still within factory acceptable range.
IF you don't like the feel of the car at high speed put 1/16 toe in on front
this is subject to personal prefrence.
Avoid the temptation to use the 30mm sway bar or go back to the 26mm bar.
(for now at least)
As mentioned retrofit the 9.5 rims up front so you can use 275 or 285's all
the way around.
examine your driving technique and make sure you are not charging into
corners (software problem vs hardware problem ???)
See Ya On track!
mv
Old Aug 26, 2003 | 04:45 PM
Jim 47's Avatar
Jim 47
Trade the 96 C4 for a C5.
Get sticker tires.
Fiddle with the tire pressures.
Just where are you experiencing understeer? Sure hope it's not on public roads.
Jim
To Understeer
