C5-R front diffuser pix?
Old Aug 24, 2003 | 08:26 PM
TLGunman's Avatar
TLGunman
Default C5-R front diffuser pix?
I'm curious if anyone has pictures of the C5-R's front diffuser? ie underbody pix from the front splitter back to the front axle line.
Ditto on the front diffuser section of the Saleen S7R.
If you could post, or IM me, and I can give you an email addy, I'd appreciate it.
Old Aug 27, 2003 | 06:07 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: C5-R front diffuser pix? (TLGunman)
you mean the under tray?
Old Aug 27, 2003 | 08:56 PM
TLGunman's Avatar
TLGunman
Default Re: C5-R front diffuser pix? (John Shiels)
Yes, the forward section, from the leading edge of the splitter, to the front axle line is my primary interest, but the full underbody would be cool too.
Old Aug 28, 2003 | 02:44 PM
davidfarmer's Avatar
davidfarmer
I'll try to get a couple shots at Laguna Seca next week, but can't make any promisses.
Dave
Old Aug 28, 2003 | 09:01 PM
TLGunman's Avatar
TLGunman
Default Re: C5-R front diffuser pix? (davidfarmer)
Thanks Dave!
Old Aug 28, 2003 | 11:06 PM
davidwp97's Avatar
davidwp97
If you could post, or IM me, and I can give you an email addy, I'd appreciate it. Thanks
Would some pix like the above help? I posted several at:
http://palmeter.com/C5RSeb2003W2P01.htm
Let me know what you think.
David
(Sorry, I don't do Saleens.)
Old Aug 28, 2003 | 11:42 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: C5-R front diffuser pix? (davidwp97)
David
Great pics!! Thanks for sharing!! :cheers:
Old Aug 28, 2003 | 11:44 PM
davidfarmer
Default Re: C5-R front diffuser pix? (Gary96LT4)
This is almost identical to our World Challenge splitters. We run a integrated "laguna" undertray, very similar to the picture shown. Mine extends back to the front subfram, and it looks as though the C5R is similar.
Dave
Old Aug 29, 2003 | 08:20 AM
TLGunman's Avatar
TLGunman
Would some pix like the above help? Let me know what you think.
Perfect!
Ah, but one can learn alot by studying the enemy ;)
Thanks for the pix. The C5-R is very similar to the MT900's front underbody.
Old Aug 29, 2003 | 04:14 PM
davidwp97's Avatar
davidwp97
Glad they were helpful. Does the MT900 use the same front underbody for both the street and the race versions?
David
Old Aug 29, 2003 | 06:53 PM
gstama's Avatar
gstama
At what speeds does it work and what is available for the street/track C5.
Old Aug 29, 2003 | 07:42 PM
John Shiels
Default Re: C5-R front diffuser pix? (gstama)
you use it in conjuction with the splitter like David Farmer has. It makes a suction under the car
Old Aug 30, 2003 | 11:26 AM
davidfarmer
The C5, being a "bottom sucker" cannot use a splitter/undertray with the OEM nose. We run an aftermarket nose, which is identical to OEM except that it has the cut-out in the center, and a closed floor. When combined with a splitter and venturi, it genterates several hundred lbs of downforce. ACP offers these pieces for street car, although ground clearance is a real problem on the street.
Btw, the C6 is supposed to be a "front breather", and should benefit from bolt-on airdams/splitters.
Dave
Old Aug 30, 2003 | 12:56 PM
TLGunman's Avatar
TLGunman
David
Yeah, the front underbody of the MT is exactly the same for street and race cars.
To C5-R front diffuser pix?
