steering rack - does anybody replace rubber with solid alloy
Old Aug 1, 2004 | 05:26 PM
ukchevybuilder's Avatar
ukchevybuilder
Default steering rack - does anybody replace rubber with solid alloy
I know C4's are a bit old now with regards to racing but I when people raced them did they replace the rubber bushes that locate the rack with polyurethane or solid alloy?
The drivers side mount sems to do all the lateral location with the pasenger side one supplying only axial location ( apart from any gripping efect on the smooth rack tube).
Any info on modifying the mounts on a C4 ( and C5 if relevant ) would be greatly appreciated.
Old Aug 1, 2004 | 09:16 PM
davidfarmer's Avatar
davidfarmer
Any machine shop could make them up for you, but don't know of any pre-made units
Old Aug 1, 2004 | 09:53 PM
larryfs's Avatar
larryfs
does your rack "knock" with the engine off?
engine off, key on, you turn the wheel back and forth, I could feel the slop and it makes a knocking sound.
I'm just wondering if it's common?
Old Aug 2, 2004 | 12:05 AM
MUKAK's Avatar
MUKAK
I know its common on MUSTANG but not the C5s
Old Aug 2, 2004 | 06:49 AM
larryfs's Avatar
larryfs
C4's..
1996.
Old Aug 2, 2004 | 11:45 AM
ZR1 MK's Avatar
ZR1 MK
Urethane is available.
Old Aug 2, 2004 | 01:15 PM
loiq's Avatar
loiq
You could make some out fo Delrin, too.
To steering rack - does anybody replace rubber with solid alloy
