correct pedal height needed
Old Sep 28, 2004 | 06:01 PM
DaveL82's Avatar
DaveL82
Default correct pedal height needed
I have the complete dash and steering column out of my 80 that I just install a hydraulic clutch linkage in (was an auto car).
I need to know the optimum pedal heights for the brake pedal and clutch since these are now fully adjustable. Need heights either from floor perpendicular to the flat surface of the brake and clutch pedals or height above accelerator pedal.
I will be adding an adjustable stop in the floor for the clutch to limit clutch master travel per the Tilton spec. so pedal free height is most critical measurement.
Car is being built for autoX, high speed road events and occasional track time and remain reasonably streetable.
Dave
