Splash shield staples help!
1966 327/300 roadster no A/C. I purchased a new splash shield and rubber weather-strip but how in the heck do you staple the rubber to the metal splash shield? Or is there a better way?
Mike
chuck
I had to drill some new holes in 2 spots cuz the guy that originally stapled'em missed the metal with one end of the staple
When you do the shield with the curve, staple the curve FIRST then go toward ends.
I had a hard time keeping the rubber in place while trying to drill the 1/16 hole in the shield. I found it easier to make the holes in the sheet metal then poke the staple through rubber.
I had to peal the edge back on the rubber to spot the existing hole in my splash pan and then I used a leather needle to poke all the way through the rubber, this worked pretty good.
I tried drilling while 'in place' but found I had too much trouble keeping the drill bit from wandering while trying to drill the sheet metal.
The next hardest thing is to hold staple in place while trying to bend it over, I have a hunk of steel I used as an anvil, it is a round piece about 3-1/2" high 4"dia a base and has a 1"dia flat top (cone shaped).
I supported the head of the staple on this anvil and used point nosed pliers to start bending then used a flat nose punch to finish the bend.
Just take your time and you will be OK
my .02
Chuck
chuck
FYI
** The silver duct tape I used left a lot of the tape adhesive on the shields when I removed the tape Maybe painters tape would be a better option **
Good Luck Chalie
Dennis
