327 Block Code
Old Feb 28, 2005 | 12:24 AM
phamill's Avatar
phamill
2nd Gear
Default 327 Block Code
I'm preparing to rebuild/replace the 327 engine in my 61. I was told when I bought the car that the engine came out of a 62 vette when they restored the '61. Looking up the block number and trying to decide on whether to rebuild the 327 or put in a 283 I found the following info on the casting ID (3959512):
3959512, 327, 62-67,
2, Was also used for some replacement blocks ...
If this 327 is a replacement block would that be any reason to keep the block versus going to a 283 to match the original specs? -- Tired of saying "yeah I know the '61 didn't come with a 327 option..."
Any help would be GREATLY appreciated.
Phil
Old Feb 28, 2005 | 07:23 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Just say the 327 runs stronger than the 283. No reason to change unless you plan an NCRS judging.
Old Feb 28, 2005 | 07:36 PM
chris ritchie's Avatar
chris ritchie
What's your question, Phil?
That block is the wrong one for your car. It's not from a 1962 Corvette either. The '62 Corvette took a 3782870 block. Not sure what motor you have. But what do you care? It's not correct for your car. So it could be anything. Only you and your machine shop know whether it's worth rebuilding. Is it better than a 283? Sure, but so isn't a 350 and a 383. Are you also considering them? If you're not going to go on a search for a correct 283, you can use anything you want.
I don't understand what you mean by telling people that the '61 didn't come with a 327. You can fix that easy. Don't tell them. All small blocks look alike.
To 327 Block Code
