Small Block Question
Old Mar 14, 2005 | 10:08 PM
BigBlockOffroader's Avatar
BigBlockOffroader
Default Small Block Question
I have a new , just uncrated 350 ram jet. I installed the drill with the oil primer and I can not get oil on the left (passenger side) rocker arms. The other side after 3 - 5 minutes was oiling but I never got oil to the other side. Anyone got any Ideas? I know I have heard of this before but whats the solution.
Old Mar 14, 2005 | 10:59 PM
67L36Driver's Avatar
67L36Driver
Rotate crankshaft a little at a time untill passage in main journal line up with passage to left bank.
Old Mar 14, 2005 | 11:37 PM
BigBlockOffroader
Much Ablidged Aprreciate the info
Old Mar 15, 2005 | 11:02 AM
MasterDave's Avatar
MasterDave
Moderator
Just spinning the oil pump will do just as you describe. You need the proper tool (at any auto store for under $20). Then you will get pressure to both sides.
To Small Block Question
