anyone else using a fuel return line?
Old Mar 26, 2005 | 05:33 AM
Matt Gruber's Avatar
Matt Gruber
Default anyone else using a fuel return line?
how and why, is the topic
Old Mar 26, 2005 | 08:59 AM
67ratrag's Avatar
67ratrag
High volume fuel pumps feeding high HP engines usually require a return line to the fuel tank so the back pressure doesn't burn out the pump. I have a braided #10 line to a fuel log feeding the holley, then a braided #8 line returning to the top of the tank. If you look at my pictures, specifically the frame pic, you can see some of the plumbing if you look carefully.
Old Mar 26, 2005 | 10:01 AM
Matt Gruber
thanks 67ratrag for the high hp answer.
Does anyone know when GM started using them, and why?
Old Mar 26, 2005 | 12:25 PM
vette rod's Avatar
vette rod
Return lines keep the fuel cool and minimize air bubbles.
Old Mar 27, 2005 | 06:05 AM
Matt Gruber
1. stops vapor lock at fp
2. bleeds off pressure, reduces hot soak flooding
Who knows how the 3 line fp works?(what is inside different than 2 line)
Old Mar 27, 2005 | 12:12 PM
gofastvette's Avatar
gofastvette
Basically found on AC equiped cars. Nothing to do with fuel pressure as anything over 7 lbs will blow the carbs needle and seat anyway.
Old Mar 27, 2005 | 02:24 PM
Matt Gruber
without a return line, on a hot soak, the fuel in the line between the fp and carb, can boil, flooding it.
Who know how to rig a "defacto" return line(invisable to NCRS judges)? (to reduce this hot soak flooding)
Old Mar 27, 2005 | 06:58 PM
gofastvette
If you have a performance Vette, or any performance engine for that matter, your home free because they dont need one unless it`s air conditioned. A hot soak is what you get in a Hot Tub with a female companion.
Old Mar 27, 2005 | 09:37 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
My non AC 65 GTO has them. How about any earlier cars? Don't know why. Maybe emissions related?
Old Mar 28, 2005 | 12:39 AM
waynec's Avatar
waynec
Nassau, are you sure it's a fuel return line... could it be a vapor line connecting the fuel tank to an emissions vapor charcoal canister?
The carb fuel bowl is also connected to the canister.
When the car is not running and heat causes vapors to be expelled from the carb and from the fuel tank, it flows through the canister, where the fuel in the vapor is absorbed by the charcoal; then when the engine is started, another hose causes suction that moves outside air through the canister, past the charcoal, vaporizing the absorbed fuel and pulling the vapor into the intake to be burned.
To anyone else using a fuel return line?
