Sure could use your help. With regard to a 67 big block car, if the car is tuxedo black with a red scoop, what is the paint code for the red ?
Secondly, is there a stencil or something that will properly line up where the red goes on the scoop at paint time..
Thanks in advance,
Yes, there is a stencil you can buy, or you can decipher the A.I.M. it is in there. There isn't a paint code for the stinger color on the trim plate it is based of your exterior/interior color.
