HI
As some of you know I reacently purchased a 64 convertible.
I was just wondering what your cars rev at at 60mph, mine is close to 3000 rpm at 60. It is a 327 365hp 4spd, I don't know what ratio the rear end is yet. I do know that this engine has awesome torque
Thanks Cole
My guess is that you are running a 3.70 rear end assuming that your tire diameter is 27" and your four speed is a Muncie. If it was a 4.11, you would be around 56 mph at 3000.
It doesn't matter what the tire diameter is. The speed/revs relationship is fixed by the speedometer gearing. Different than OE revs per mile tire will just increase speedometer error.
The revs at sixty are simply the OE tire revs per mile times axle ratio.
It doesn't matter what the tire diameter is. The speed/revs relationship is fixed by the speedometer gearing. Different than OE revs per mile tire will just increase speedometer error. Duke
Absolutely correct for the two relationships - I mention tire diameter due to its effect on actual speed vs. indicated speed (error); I check error by timing the exact interval between measured mile markers on the freeway at a constant indicated speed, and my watch (chronograph) reads the true speed directly on the dial to compare with the inidicated speed held during the measurement mile.
I can confirm that your data suggests a 4.11 rear end, plus I suspect you have asked because it might seem to be high (read noisy) for a gentle highway cruising speed - yup. Do you have sidepipes? Lots of "music" going on . . .
Signed, Jack with the 365 hp 4.11 rear end sidepipe vert, hoping to listen to the music soon if it EVER stops raining or snowing in the NorthEast!
760 x 4.11 = 3123
760 x 3.70 = 2812
Duke
No disagreement here either, I was also just referring to "actual" speed (as opposed to indicated speed) and rpms for comparison and, obviously, tire diameters different than stock diameters will have an affect on actual speed versus indicated speed... But heck, Duke, you knew that...
Nobody knows there actual speed unless they go to the trouble of calibrating their speedometers, and I doubt if anyone other than John and myself have done that.
In the context of the original question the reasonable assumption is that the indicated RPM and speed were listed.
...In the context of the original question the reasonable assumption is that the indicated RPM and speed were listed.
Unfortunately, over the past 40 years a number of Corvettes have had their tire sizes (diameter) changed (for various reasons such as larger tread, radials, etc.) as well as having the speedo driven gear swapped to match the tire change (swapped in an attempt to retain close to correct speedo readings, and it's an easy swap). Now, unless these things are also known as a certainty, measuring your actual speed, tire size, etc. ~does~ matter and would need to be divulged in order to truly and "accurately" determine the rear ratio.
