Poly-lock torque spec?
Old Mar 26, 2005 | 08:57 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Default Poly-lock torque spec?
Is there a torque spec for poly-locks? I've always just cranked them down. I'd rather do them right if there is a right. Thanks.
Old Mar 26, 2005 | 09:43 PM
John McGraw's Avatar
John McGraw
There should be no difference between the torque spec for a bolt with a poly lock nut and one with regular nuts.
Old Mar 26, 2005 | 10:34 PM
nassau66427
Sorry, I guess my question wasn't clear enough. I'm using poly-locks on my roller rockers and was asking if there was a specified torque value.
Old Mar 27, 2005 | 10:47 AM
yooperod's Avatar
yooperod
I couldn't find a spec when I needed it.
So if you find it ,please post it
I torqued the allens to 20 lbs,
a number i just picked out of the air.
rod
Old Mar 27, 2005 | 11:00 AM
Matt Gruber's Avatar
Matt Gruber
I torqued the nut to 20 lbs,
rod
i used the same air, 20
To Poly-lock torque spec?
