Vibrations
Old Mar 27, 2005 | 03:57 PM
autocolor's Avatar
autocolor
Default Vibrations
I am getting a vibration through the car particularly the steering at low speeds 35 - 40 mph on over run and with light throttle , it all seems ok under acceleration and at higher speeds .
I have checked all steering componants , wheels , tyres etc and I am convinced it is coming from the motor .
I have just fitted new engine mounts ( standard side mounts ) is it possible one or both of these are "solid" rather than rubber ? does this fault occur in manufacture ?
For info the car is a 61 running with aftermarket suspension , coil overs and rack and pinion steering all new , the motor is a pretty standard 350 ci with a 350 auto box ( just rebuilt ) .
Any reccomendations on steering geometry set up for normal road use would also be appreciated .
TIA Mike .
Old Mar 27, 2005 | 05:01 PM
62fuelie's Avatar
62fuelie
Check the driveshaft. I had a similar condition on a 61 and found a bent driveshaft. Also, on C1's, the driveshaft angle can be a vibration problem. If your transmission mount has no spacers between it and the crossmember, try shimming it down a 16th or an 1/8. This decreases the u-joint angle. Last, check the bushing in the transmission output where the yoke goes. Excessive wear there can cause a problem.
Old Mar 27, 2005 | 05:29 PM
autocolor's Avatar
autocolor
Driveshaft is new and balanced with a new UJ at the box end , the box tail cannot go any lower without it fouling the X member , I already have the box mount down around 1/2" .
The 350 box replaced a Muncie and all the mounts / adaptor plate are the same as used with that and there were no vibration problems .
The problem only seems to be on the engine over run or light / feathered throttle .
I will be replacining the box rear mount just as a precaution but it looks ok .
The engine was on the original 61 mounts before instalation of the new suspension but these needed to be removed to accomodate the new steering shaft for the rack and pinion , hence the introduction of the side mounts .
Thanks for your thoughts
Mike
To Vibrations
