distributor dimple question
Old Mar 28, 2005 | 10:07 AM
xsray's Avatar
xsray
Default distributor dimple question
Should the rotor line up with dimple before the distibutor is dropped in or after?
Old Mar 28, 2005 | 10:24 AM
Dave62's Avatar
Dave62
Put the rotor button on the distributor shaft top....
The dimple on the gear at the should be lined up with the tip of the rotor button.....always as they trun together....only two ways to put gear on....dimple in line with tip of button...and 180 degrees out...which could/will cause probelms with timing of motor as vac can will not be in correct place and can interfear.
Dave 62
Old Mar 28, 2005 | 10:38 AM
xsray's Avatar
xsray
Thanks, they move together.
To distributor dimple question
